Originally Posted by cptsideways
Actually you don't need to. A vertical wing that's 90deg to the wind will create lift laterally (read that as centrifugal force in cars terms) I've always thought a gravity racer could use it easily for cornering & not braking.
Certainly, but if it's big enough to react quickly to steering changes and produce meaningful force it might be a problem for side winds.
