Old 07-07-2014, 02:49 AM   #24 (permalink)
Xist
Originally Posted by California98Civic View Post
Will expanding foam stick to duct tape? I am wondering about a removable insert grill block for my front bumper that would simultaneously lower the stagnation point. I imagine the finished product being bolted to the grill from inside the grill, on the engine bay side, for easy removal.
Expanding foam seems to stick to everything, it actually pulled the surface off of our driveway when I scraped it off.
Perhaps Aerohead addressed this directly elsewhere, in this post he talked about expanding foam and release agents for fiberglass resin, which should be applicable:
*The polyisocyanrurate foam is chemically similar to urethane,so polyester resin is okay with it.
*Aluminum foil can be squeegied on over a coating of general-purpose axle grease,directly on a finished automotive finish to create a bleed-proof block and release mechanism for wet-layups applied directly over a vehicle when integrating spoilers,tails,and whatnot.The foil itself can receive multiple carnuba waxings along with a coat of polyvinyl alcohol release agent prior to laying up to release the foil from the part after the cure.
After the 'part' is completed,you slip it off the car,peel the foil away,then GUNK the area to remove the grease.
Have you read this thread? Jedi Sol said the foam sticks to foam, I would expect it to also adhere to duct tape.
California98Civic (07-07-2014)
