Old 07-08-2014, 04:39 PM   #96 (permalink)
Enki
Enki's Avatar
Figured I'd update this thread with my "jump box" (which has been renamed "DeathBox") progress.
I need to finish the paneling, mount the ballast/drain lights, and then wire it up and then it can be used to jumpstart cars; mostly, it will be used to start-assist my dad's racecar which has no alternator and requires lengthy pit sessions on the charger before it can go back out and make another pass. Hopefully, this will allow for two passes before pitting at the worst.
ID:	15342   Click image for larger version
ID:	15343   Click image for larger version
ID:	15344   Click image for larger version
ID:	15345   Click image for larger version
Name:	IMG_20140704_151407 - Copy.jpg
The Following User Says Thank You to Enki For This Useful Post:
mpgmike (01-04-2022)
