Old 07-08-2014, 08:39 PM   #3 (permalink)
user removed
If the transmission is leaking that does not mean it needs to be rebuilt. Imput shaft seal or axle seals are the only leak points. Leaking at the bottom of the bell housing is imput shaft seal and you need to drop the tranny. Axle seals can be done with the tranny in the car. Could be as simple as the axle not being completely in place. Imput shaft bearings seem to be the most common bearing failure in Hondas. You can tell if the bearing is noisy by putting your ear on the shifter and listening for the noise which sounds like nuts rolling around in a can.
Might also be the speedo sensor o ring.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
Baltothewolf (07-08-2014), Ryland (07-09-2014)
