Old 07-09-2014, 06:58 AM   #3 (permalink)
user102
Check out the instrumentation section. I believe MPGuino is what you're looking for.
Ok thanks.Quick question given this ecu is it possible to interface with it using an arduino based system to gain access to some other engine parameters such as throttle position,engine temperature etc and if so what compatible system am I looking for ?
