Originally Posted by RustyLugNut
The bottom line is that considerable work will need to be done to gain a 5-15% advantage. An outlier engine returned 30-50% with HHO but that was in conjunction with added intake heat, mixture turbulence and lean combustion mixtures at relatively low engine revolution rates.
Sounds like everything but the HHO was improving fuel economy.
Up to 15% is what I would expect from WAI, lean burn and cruise RPM reduction.
