Do you have to run the 1980s classic 235/75R15 tire size for any particular reason?
That is what my suburban should have, I put 31 inch tires on it.
Generally, larger tires mean lower fuel economy, so replacing my 28.9" standard with the 31 would result in lower mileage. You might think otherwise since the larger tire size acts like a differential reduction, but most everything I've read suggests this.
