Old 07-10-2014, 11:21 PM   #10 (permalink)
Cobb
Good point. One reason you should measure the coolant going into the vehicle. I find when you add the water wetter it makes the coolant go in better and avoid the air traps. I always fill up the over flow bottle so if I miss some it can suck it out as needed and check it a day later.
Originally Posted by nemo View Post
Sure you got all the air out of the system?
