Originally Posted by Rishar
I'd go for out the trunk. Blowing air in would push it up to you whereas out would pull air from the front of the vehicle, helping to cool you as well
I would have went for the opposite, blowing air into the trunk. If you suck air out of the trunk then it is replaced by air entering from all the little gaps and drainage holes. Bringing all the collected dust and dirt into the trunk.
Blowing air into the space is the way it is done in the passenger area so i would do the same.
I wouldn't imagine it would require a great deal of air flow and also it would only be used during charging so you wouldn't be in the car to be impacted by the small amount of air that may make it from the trunk into the passenger area.
