Old 07-11-2014, 04:58 AM   #6 (permalink)
cRiPpLe_rOoStEr
It sounds even more challenging to do so in such a small rig than in a regular pick-up truck. due to the usually tight space available for the drivetrain. Anyway, I would probably get a small Diesel engine, maybe turbocharging it, with an alternator beefy enought to also generate some power to the electric drive. You could consider to replace the front differential with an electric motor (which must be reversible), keeping the rear wheels still driven by the internal-combustion engine even if you would ultimately manage to get them also driven by another electric motor. You could eventually try a BAS-Hybrid layout similar to the hybrid versions of the Chevy Malibu, Saturn Aura and Saturn Vue.
