07-11-2014, 11:52 AM
#15 (permalink)
Originally Posted by pascal28
I have just taken the bonnet off my Honda Insight G1 and weighed it (aluminium part only i.e. excluding hinges, heat/noise shield, rubber seal, windscreen spray nozzles and tubes, bonnet stay, bolts & lower catch mechanism). I got 6.0 kg (13.2 lb) exactly.
I agree with Red Lions comments regarding the type of weight that would be possible from a CFRP resin infused solution (~7 to 10 lb).
Thus, as Honda did such a good job with the Insight's bonnet, there is not much to get even from a well made CFRP version - won't stop the brave from trying though...
Done (9.6 lb):
CFRP Bonnet (Hood) - Insight Central: Honda Insight Forum
