Old 07-11-2014, 12:03 PM   #14 (permalink)
oil pan 4
Originally Posted by lasitter View Post
I wish someone would speak to my issue which is one of width vs tire diameter.
The case that I'm looking at involves shrinking the tread width (and approximately the contact patch) by about 14 percent.
I understand that this has completely separate implications (usually bad) for traction, handling, stopping distances, etc., but I am focusing on the fuel economy benefits alone here.
Contact patch is obviously what holds up the vehicle. Barry has said in the past something to the effect of a smaller contact patch typically causes higher rolling resistance when the same load is applied to the tire with the same air pressure and that the smaller tire will deform more, building more heat.
I say building more heat on a smaller tire surface = bad.
And what does the smaller tire do you your carry capacity?
