Again, having owned an insight and felt it out its a conclusion many come to. The least you use of the ima system the better your mpg is.
To cancel the auto braking regen of the gen 2 you just need to put light pressure on the throttle. To get more regen braking press the brake petal enough to turn on the brake lights. For more, click the left paddle while holding the brake petal.
