I use it to run more grill block and keep the engine happy, use less cooling fan ie POWER.
In stop n go traffic in the city with no ac and auto stop in full effect I see the engine temp hover around 154 degrees F. Last time I had a rental car and hooked up my sg2 I notice the vehicle seemed to have more control over its temperature.
Of course I dont EOC, the engine spins and the water pump, pumps the whole time. I imagine if you EOC in a regular vehicle you may actually see the temp go up vs down unless you are engine braking.
