I went to install my blower today and while thinking about where to put it I discovered that there was a vent under the trunk lining right next to the charger. So I cut away the lining and flipped the charger around so the fan would suck in fresh out from the outside!
I'm going to test that out for a while and maybe add a few small fans instead of the 320 CFM blower.
I'm also going to redo the headliner as its coming apart. I found some real nice foam-backed headliner material at the JoAnn Fabrics nearby so I will buy some once I get to that project.
