Old 07-13-2014, 10:26 AM   #1 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
13" rims versus taller fifth gear swap
Need some expert advice here for possible MPG upgrade to the hooptie!
Black Widow has the stock 12" Festiva rims, so I've been considering a swap up to 13" rims ever since I have owned it. I've seen a lot of Festiva owners swapping up to 13" using the Aspire hardware, but I'm not sure doing so would benefit MPG or not. The Aspire rotors & calipers would be stouter, but would also add weight. I assume the difference in tire size would leave me with lower RPMs at higher speeds, but not sure if it would benefit MPG to do the swap. Also, would I need to do anything to make the speedo & odometer show correctly?
Would it make more sense to just swap to a taller fifth gear (if it's even possible in that car), or is there a different gearbox that would work for the Festiva? It doesn't have a tach, so I'm not sure what RPM it's hitting at 55 (my max speed), but I've seen that a lot of you guys swap fifth gears with Civics & Metros with good results.
If anybody can clue me in, I'd owe you one!
