Old 07-13-2014, 04:26 PM   #33 (permalink)
figit090
Black Bovine - '86 Toyota Supra N/A base
90 day: 16.86 mpg (US)
Grey Sandy - '03 Toyota Rav4 Sport Package
90 day: 21.3 mpg (US)
Panda - '03 Volkswagen Jetta TDI wagon GLS
90 day: 44.17 mpg (US)
Originally Posted by cowmeat View Post
Concerning the brake booster while the engine is off:
Although you'll only get one or two pumps of the brake pedal before the booster freezes up, you can make the pumps last as long as you want. I've learned to apply the brake gently with one long gentle pump while I EOC up to a long light, and then instead of pumping it again, just apply more pressure. I've never ran out of pedal so far using that technique.
I also brake early and time the lights, so most of the time I'm able to bump start instead of actually stopping.
FYI: Keying on while the booster is frozen up will immediately drop the brake pedal to the floor, so you'll need one pump to get brake pedal back! Don't wait until the last second to key back on if the booster freezes, do it early.
Haha, good tips thanks! I'll be looking more into the wear and tear on syncros, engines and clutch parts with different techniques. I think if I can manage above 40mpg without using hypermiling techniques I'll be plenty happy.
