Old 07-15-2014, 09:55 AM   #11 (permalink)
niky
Originally Posted by peterrr View Post
If you have only so much fuel to burn and you want to introduce water vapour in the process it is countereffective to use the fuel to make the water boil and convert it into steam. Air cooled LPG engines also use the exhaust heat to vaporise LPG
Water cooled LPG engine uses exhaust heat to vaporize LPG.
Originally Posted by RedDevil View Post
What do you want? Who are you? Why do you post here?
Contextual bot?
Time traveller?
Medium channeling Tesla? (though the signal to noise ratio is poor)
The Following User Says Thank You to niky For This Useful Post:
RedDevil (07-15-2014)
