Originally Posted by chefdave
Hi freebeard again
can these half rounds be used on rear to help reduce drag. Do you need to use 4" or can i go up to 6"
Thanks
dave
There's not a lot of published data which addresses your question.
Here is a drag table for bus type vehicles.You can see that softening the rear vertical edges DOES lower drag.
