But make sure the max motor amps isn't programmed to 800!!!!. That would mean 800 PER IGBT!! FOR 800 motor amps, you would program max motor amps to um... what is 800/3? I'll send over an 800amp default motor amp hex file so u dont need to get a serial cable.
Oh ya, and I will reduce the deadzone. But not all the way to 3%. This needs to stay conservative. If it seems like there is still too much when I send this, I can readjust it. Also, you can program the deadzone thru the serial connection.
