Old 07-16-2014, 11:58 AM   #6685 (permalink)
jedsmd
PLUGnGO
jedsmd's Avatar
Originally Posted by MPaulHolmes View Post
But make sure the max motor amps isn't programmed to 800!!!!. That would mean 800 PER IGBT!! FOR 800 motor amps, you would program max motor amps to um... what is 800/3? I'll send over an 800amp default motor amp hex file so u dont need to get a serial cable.
Paul
Great that will get me going down the road
If you connect a computer to the serial port you can adjust the max amps yourself. Do you have a computer with com port ? or serial USB cable?
Flores
I have a laptop with a serial port. But I'm clueless. What software would I need?
Jerald
