Originally Posted by 2000mc
in your fuel log, looks like one of the last mods before your best tank was changes on the belly pan, so it might be worth making a check that everything is tight, or might not bend or bow down at 60mph. grill block setup for the temps? (fan running excessively?)
I've been thinking that something was messed up. But then the higher mpg today really really confused me. Maybe today is just a fluke as it doesn't correspond with the science of ambient temps.
I need to have a way of monitoring when the fan is running. I'm not sure it would kill my mpg as much as I've noticed, but it certainly would affect it. I haven't noticed my coolant temps spiking, but if the fan were running a lot then that would keep the SG from showing that.
I hadn't thought to check the belly pan. I will.
