Old 07-17-2014, 02:12 AM   #32 (permalink)
freebeard
Tesla could not call their next car, "Model E". Ford apparently sued them from using that moniker....now BMW has a beef with it.
Now that's funny.
Low aero drag, free wheel coasting (with regen only when the driver needs it) and improved wall-to-wheel efficiency. The '7' has an AC synchronous motor, so no permanent magnets dragging when you coast. It loses just ~8% vs the ~15% for typical EV's, because it uses no BMS. They bottom balanced the pack (99 CALB 100Ah cells) instead. Much less heat during charging - less heat means less energy lost.
This is relevant to my interests. I may get one shot at having an electric car. I'd like to see a $2-4000 conversion and 20-40 mile range. Do you think it would be possible to go with AC in that scenario? Could you suggest other threads or search terms to try?
