Originally Posted by cowmeat
You can check the timing with a timing light that most auto part stores will rent or loan you, but as far as checking to see the cam/crank alignment, that's more complicated and you'll definitely want to watch the video if you've never tore one apart before
Here's a diagram: I NEED THE TIMING MARKS FOR A 1994 HONDA CIVIC. - Fixya
Here's a (generic) video:
If you meant using the timing light to check the ignition timing off of the distributor, it's safe to say that I've done that part already.
However, I do have another question regarding this topic. What does it mean when other people say that the timing belt is a (tooth off)?
