That's why I sent you the pic and the video. The timing belt wouldn't be the issue, it's the cam or crank jumping a notch, or were off a notch when (I assume some git er done) replaced it
The pic shows the timing marks (but like 2000mc said, make sure it's the right one)
The video would show you the steps to remove the covers you'll need to get to to be able to see the crankshaft timing mark and the cam timing mark
Once you re-align the cam and crank you'll have to use the timing light again to make sure it's at the correct degrees before TDC
Get the manual, but in my honest opinion, with the quesions you're asking, I'd get somebody that has done it before to help you, or get a shop to do it.
If you have an interference motor you can kill it if you don't have the timing right and try to fire it up . . . . .one revolution and you can bend all the valves. I don't know if those motors are interference, but I wouldn't chance it
