Old 07-17-2014, 09:14 PM   #18 (permalink)
Davo53209@yahoo.com
Originally Posted by vrmouseyd15b View Post
OK then, did you put a jumper wire in the 2 pin plug at the front passenger seat kick panel ( it will give you a check engine light when it's in place, and if you have pending codes, they will flash ) before you set your electrical timing ( with timing light ) ?
If not, not timing may not be correct. the jumper ( with check engine light lit )allows you to adjust the electronic timing at the distributor without the ECU messing your settings all around. You might want to put a jumper in the 2 pin ( there's also a 3 pin one, I think it's called an scs connector - don't touch that ) and double check your timing with a light. This may be your whole problem. It might have been ok when you adjusted it, but as the conditions change ( temp, humidity ) the ECU will want to adjust the timing slightly. If you aren't in the " middle" of this swing, that could be it.
Make sure you are at operating temp, which usually means wasting gas idling, unless you can do it right after a drive - before you check timing. clip the plug wire closest to the harmonic balancer with your light ( farthest from the dizzy ) and check again.
( You want to be in the middle of the three marks that are close together, I run mine a little "retarded" - on the line closest to the front bumper )
Yes Sir, all that was done and thankfully, there were no CEL's. The check engine light remained solid when I had jumped the 2-pin connector under the kick panel.
The only exception to any of this was that I performed each procedure with a cold engine. With that said, I think that I may attempt to repeat the entire procedure with a warm engine.
