Old 07-17-2014, 10:25 PM   #22 (permalink)
XYZ
Originally Posted by basjoos View Post
The thermal expansion coefficient for gasoline is 0.00053, so if the pilot filled his tanks with 100 gallons of gas at 60 degrees F in the morning, that pilot's tanks would be holding 101.59 gallons of gas when the temps got up to 90 degrees F later on that day. But, pilots flying distances cross country usually climb to a high altitude for more efficient flying and the air temps at 25,000 feet certainly aren't going to be at 90 degrees F.
The temperature lapse rate is 3.56 degrees F /1000 feet. If the pilot took off from an airfield at 1000 feet above sea level on a 90 degree F day and leveled off for his cruise at 25,000 feet above sea level, his outside air temp would be 5 degrees F, so the fuel wouldn't remain at a temp of 90 degrees F for very long. Since the big radial engines used by air racers in the 1930's typically had fuel burn rates in the 20 to 30 gallons per hour range, even if that pilot had a 1.59 gallon increase in fuel on board, that increase would only translate into a few minutes of additional run time. I guess every little bit of advantage they could get helped.
You can recite all the figures and calculations you wish to convince everyone. You may be right. Your statistical analysis may or may not be convincing to everyone reading it.
However, the important and pertinent concept involved is that gasoline expands and vaporizes as ambient temperature increases.
I've heard that in many ways on this list, from those who are proponents of hypermiling and seeking every advantage possible. I would think this possibility (and probability) might be of interest to those who try to conserve energy, no matter how small the gain.
Everyone can do as they please. But I will still avoid fueling up late in the day when the ambient temperature is over 90 degrees, if I can. By doing so I have nothing to lose - and possibly something to gain, no matter how small the gain.
