Old 07-18-2014, 06:41 PM   #11 (permalink)
aerohead
sail panels
Originally Posted by oldschooleco View Post
hmmmm i like the idea of fender skirts, i can definatly make something work. what about sail panels? coming from the side edges of the roof?, or on the edge of the the body near the tail lights?
I found a blueprint for a 1968 Dart GTS Hemi online.I looks like your car.
With rough measure,it looks like the aft-body of the car constitutes about 34.6% of overall length and your existing backlight is at 30-degrees to the horizon.From backlight header-to-rear of trunklid you have about 14-degrees of slope.
From Buchheim et al research of fastback cars from 1981,at this length,your backlight would be at about 18-degrees for the lowest drag.
18-degrees occurs about two gas cap diameters behind the back of the gas cap,or about half the length of the trunklid.
Since you have a notchback,we might guess that you don't need any kind of rear spoiler.Your trunklid is already too long,aerodynamically.
If you extended the C-pillars back halfway across the trunk you'd create the 18-degree slope in elevation.
If you filled in the void with a series of stepped, louvered 'spoilers',you'd capture a vortex inside there.
You'd have some privacy.It would take some load off the air conditioning.And the outer flow should skip off the vortex with a clean reattachment without recirculation into the new recessed area.
For lowest drag,you'd have to chop your rear quarter panels to create an actual fastback.I don't think you want to go there.
As to other mods:
*There might be a chance to soften some of the leading edges,especially around the headlight buckets,or fab some plex domes,as CAR and DRIVER did on their 'Crisis Fighter Pinto' back in '74.
*Your A-pillars,drip rails,and recessed glass are a problem but I don't know of an aesthetic solution for that.
*An invisible grille block if you don't have that
*Loose the engine-driven fan and go to electric if you haven't already,or flex-fan,or good thermo-clutch unit.
*Rocker panel extensions,a couple inches
*Extend quarter panel bottoms down even with new rocker extensions
*The rear skirts would be good
*Belly pan with diffuser,according to Carr would cut Cd 0.07.
