hmmmm i like the idea of fender skirts, i can definatly make something work. what about sail panels? coming from the side edges of the roof?, or on the edge of the the body near the tail lights?
I'll point back to that other thread, and
aerohead's post
i extended the rocker panels down at the pinch welds, or is that to far in? but that sounds good i have about a week to get it together before the 2000 mile trip
Look for basjoos' Civic. He successfully used two rocker panel exensions, one each at the inner and outer tire faces. It extends behind the rear wheel and tapers into a spat. or skeg.
Make sure whatever you do won't fall off half way.
