Old 07-20-2014, 07:36 AM   #120 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by ECONORAM View Post
I am guessing this would only work within a certain RPM range? I say this because after installing an under drive crank pulley, my alternator's output is about a volt lower (just by reading the AeroForce gauge) at idle. Could the voltage output be adjusted higher? Or could one of these capacitor banks hold the voltage up at a stoplight...long enough until the engine went off idle?
I suspect your alt is just spinning too slow to make more than 13v, the regulator's not limiting it's output, there just isn't enough of it.
The supercap won't make a difference either, I just tested a 350uf bank on my Jeep, the total charge capacity is around 0.2Ah, your battery is probably around 100Ah.
