Originally Posted by Baltothewolf
After changing the manual tranny oil 3rd gear is grinding... This worries me greatly... I don't have the money to rebuild the tranny, why would just changing the oil cause it to start grinding??
Did you use factory oil or does your use motor oil. Some transmissions are particular about what you use.
Some discussion here.
http://ecomodder.com/forum/showthrea...n-oil-856.html
