Old 07-20-2014, 02:38 PM   #19 (permalink)
oil pan 4
Actually if you think about it, all modern gasoline fuel systems are vacuum driven gas vapor systems.
The gasoline is exposed to vacuum anywhere between the throttle and the top of the piston, until the valve closes and the air fuel goes into compression. When driving down the road you can expect to run between 15 and 22 inchs of Hg. That's a vacuum of -7 to -10 psi.
Heat in the fuel that gets picked up on its way to the gasoline induction system combined with exposure to the vacuum should flash all the gasoline to vapor in the warm to hot vacuum environment.
