Old 07-20-2014, 04:29 PM   #31 (permalink)
Enki
Enki's Avatar
The weight savings is very real, but minor. The load on the electrical system would actually be higher until fully charged, and then it would be about the same as a battery.
What you could potentially do, however, is build a controller so that while pulse and gliding, is have the alternator only deliver current while engine braking, using the capacitors to power the vehicle while accelerating.
How you'd implement such a thing I'm not sure, but I am sure that the gains would be measurable, if disabling load on the alt does, in fact, have an impact on economy.
