Old 07-20-2014, 05:38 PM   #8 (permalink)
Flakbadger
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Originally Posted by Cobb View Post
Ah, the 4 door saloon. I saw the little hatch back the other day and it was rather sporty looking from what I recall in 06. Yeah, those mods will add up fast on that car.
Well so far my best mod is the Ultragauge, for sure. I figure it's just flushing money down the toilet to not go for a few aero mods at this point.
Originally Posted by jedi_sol View Post
let us know how the magnets hold up!
I don't think i've seen many wheel cover/magnet covers hold up very well on EM.
Will do. I tried to reduce any slippage and use more magnets than I thought necessary. I figure it should do as well as the regular hubcap, which I lost one of anyway.
Originally Posted by fullofsol View Post
I like the look of the hubcaps, it will be something I'd like to test on my vehicle down the line as well
I like the look too. Looking forward to painting them white to match, it'll look really cool then. You should do it.
Originally Posted by Baltothewolf View Post
What did you use for the wheel covers...? Can you list parts specifically.
Sure. Besides for the 4 pizza pans from Wal-Mart (About $4 apiece), I used:
1) Double sided 3M tape; often used to hold automotive trim on your car. A roll is like $8 and I had one lying around. I used small squares and spaced 6 of them equidistantly around the rim.
2) Neodymium Magnets; found at the hardware store, about $4 for a package of 6. I used 4 packages. I put one magnet atop each piece of the previously mentioned 3M tape. The magnet would stick to the rim on its own (VERY POWERFUL) but would likely end up sliding whenever the wheel undergoes a change in acceleration. The tape will keep them from sliding, and the magnet holds the tape firmly to the rim as well. They're not going ANYWHERE.
3) Window Insulation; I used the thin, self-adhesive, D-profile insulation you'd use to seal your windows to fill the gap between the pizza pan and the rim. I did this for two reasons: To keep the pizza pan from sliding atop the magnets and becoming off-center, and to provide friction to keep it from rotating atop the magnets.
I have a crap ton of the insulation left and am going to tackle the gap between the front fascia and the hood next.
Each wheel has 6 pieces of 3M tape, 6 magnets, 3 pieces of insulation, and one pizza pan.
Thanks everyone for the replies.
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
The Following User Says Thank You to Flakbadger For This Useful Post:
Eddie25 (02-25-2015)
