Originally Posted by Daox
Could you just add a small fan to the motor (shaft)? Run it at a higher voltage, less amperage. Use your belt drive to correct for rpms.
The problem is the motor is too high of RPM, rated at 6750 RPM @ 130v. I have the smallest pulley I could find welded on the shaft so adding a fan at this point is not an option.
Ideally I would like something rated for 180v DC and runs at 3000-4000 RPMs so I wouldn't need a controller at all.
