Old 07-21-2014, 08:21 PM   #44 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
OK. I've had the new General Grabber HTS 225/70R15s on for a week now and they've been re-torqued at Wal-Mart. I haven't gone on whole tank with them yet, I have another 330 miles or more before the next fill-up if I continue filling up after 400 miles. So far, I'm pleased with the tires. They're set at 35 at the moment but I won't be keeping them there, That's just for a short time. The tires have much more grip than the last ones and the car rides quieter with the new ones, but what do I have to compare with? The old ones were dry-rotted and two of them were at least 19 years old, they even said to not set them higher than 35 PSI.
I got 19.96 MPG on the last tank which was mostly with the old tires set to 35. Fewer than 10 miles of that tank were with the new tires. Something like 200 miles of that tank were on one trip, though.
These new tires are also .3 inches larger in diameter than the old ones. Should I be checking for a discrepancy between the odometer and the actual miles put on now? The old ones were P205/75R15s.
I shot some photos including some of what spacemanspif asked for:
First, one of the car with the new tires and close to the same spot of the first photo in the thread of the car:
A closer-up image of one of the tires:
The QuadraJet Carbureter:
A farther-out photo of the Carburetor, and some of the engine:
Some of the Air-Cleaning equipment on the car. This one is behind the driver's-side headlight:
(One of the tubes was taken off for the photo and was put back on.)
(That blue part is a paper towel - or a few of them - from Sheetz to rub fluids from dip-sticks off with.)
So, What kind of a higher MPG figure can be seen from going from 35 to 45 PSI?
