Old 07-21-2014, 09:59 PM   #46 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Headers aren't gonna do squat for mileage. They only benefit in the torquey RPM range. And if you are hypermiling, you will be well below those revs.
I would be disabling half of the V8. Remove the pan, unhook the rods on one bank and secure them all at TDC, put clamps (nut & spring kind instead of gear) on the empty rod journal oil holes to stop the oil spray. Disable the valve train on the same bank. Voila, a 2.5 four banger.
And aeromod the living crap out of it.
The Following User Says Thank You to mechman600 For This Useful Post:
101Volts (07-21-2014)
