Old 07-22-2014, 01:19 PM   #53 (permalink)
cRiPpLe_rOoStEr
Originally Posted by mechman600 View Post
I would be disabling half of the V8. Remove the pan, unhook the rods on one bank and secure them all at TDC, put clamps (nut & spring kind instead of gear) on the empty rod journal oil holes to stop the oil spray. Disable the valve train on the same bank. Voila, a 2.5 four banger.
Replacing it with a real 4-cyl would be more worthwhile because there would be less dead weight to still haul around. BTW there were some Caprices from the 80s fitted with a version of the Iron Duke enlarged to 2.8L, mostly intended to be used as taxi. This engine is currently available for stationary/industrial and marine applications.
101Volts (07-23-2014)
