Originally Posted by ever_green
NM is measurement of torque. some graphs use torque instead of engine load which is basically the same thing. the top boundary of the coloured area is the torque curve. 1NZ-FXE makes about 110nm at 4000rpm, so you can say 90% load is 99nm torque (0.9x110).
Isnt engine load the power usage?: actual kW / max kW ?
kW = Nm x RPM / 9550
Very nice thread! Thanks for the results!
