Originally Posted by redpoint5
Yes, but you would need to get a much higher capacity than the 350s I'm running. Perhaps a bank of 1500s. The voltage would still sag over time, just at a slower rate.
Is there something that isn't working correctly when the voltage sags at idle?
I put a warm air intake in when I installed my under drive. I know, you should only install one mod at a time. Anyhow, the truck will not idle below 650 now. Prior to this, I could get it to idle at 450. I later pulled the warm air intake, thinking it was the culprit...but nothing changed. So then I noticed the voltage drop when the engine tried to lower to 450 rpm and started speculating that the PCM was watching the voltage to limit the idle rpm. It's a .2 gal/hr difference at idle...
Originally Posted by Enki
Lithium Ion supercaps are out now. They don't go past 270 farad ratings, and have a voltage range of 2.2-3.8 volts but charge in a minute at most. They are essentially fast charge batteries, and in larger sizes, will be a game changer.
Lithium Ion Super Capacitors - Taiyo Yuden | Mouser
Invalid Request
I can't wait for these things to get bigger.
Wow! Thanks for posting that.
