Old 07-22-2014, 04:58 PM   #18 (permalink)
aerohead
sail panels
Originally Posted by oldschooleco View Post
Did some mocking up/mounting. do you think just the sail panels would help out any? thank you
I do think they could help.They would forcibly control the 'area' occupied by the turbulence,sculpting the wake behind the roof as it were.
Pickups like the Ridgeline,Escalade,and Avalanche are using them after a fashion.
Lotus has done it.Many of the supercars have used it.
I did it with my CRX and incorporated wings and spoilers into the buttresses to further modify the separated flow.
I would give them some gentle inward plan-taper,based upon the 2D-flow wing section of minimum drag.
Here is the MG EX 181 using it for it's body
