Old 07-22-2014, 06:30 PM   #33 (permalink)
aerohead
Lrr
I'm looking at a Bridgestone, Dueller/Alenza (or something like that) LRR 235 75/R15 for the T-100.
*It has Traction AB which is better than the Grabber
*It has a treadwear rating of 800 which is almost twice that of the Grabber
*It's Revolutions per mile is less than the OEM tire and will reduce engine rpm by 4% (Rubber Gearing ).
*They were $112 each at Tire Rack's website.
Long ago,when the metric tires were coming into the USA,at least one article came out on TPC tire technology,in CAR and DRIVER.
*Larger diameter allowed each tread element fewer road strikes per revolution,and with hysteresis factored in,the tire ran cooler,wasted less energy in deforming each tread element,for better mpg.
*Quiet bands were removed,as they absorbed power.
*Noise was an issue and the EPA was considering legislation for tire noise criteria.
*Wider tires have greater aerodynamic drag although we can modify for that.
*Early LRR concept tires had no real world traction,so perhaps as far as safety goes,maybe we accept a compromise in efficiency until more black magic creates narrow,high grip.
Slowing the engine down is 'typically' an efficiency move,according to Ricardo Engineering Consultants.
And many messengers emphasize the importance for re-gearing cars which have been streamlined,to get the full benefit of a constant BSFC.
