Thread: EV build aero.
Old 07-23-2014, 03:16 PM   #10 (permalink)
freebeard
I was going to convert a small ute/truck that I could use both as a commuter vehicle and for it's practicality.
I found the answer to one of my questions. Maybe a mobile office/party van?
This is pretty close to how I'd like the rear to look. Not ideal, but not terrible either.
I would respectfully disagree. That is the ideal.
I was going to use the same radius on the edges as the roof of cab and start the side taper after the rear wheels so they are enclosed. So probably closest to the square example but with radiused edges.
The middle example is 1/2 way between a square and circle. Toward the square limit you get round cornered rectangles, like the iPhone. Aerodynamically, you'd be better off closer to the mid-range, like an Airstream trailer.
PVC is nasty stuff. Brittle and it doesn't play nice with wood or metal. How about bamboo slats?
Wainscoting - Wall Slats for Bamboo Ceiling & Island Decor | Cali Bamboo
You'd have a dimensional, millable outer face and bamboo on the interior. Much nicer than PVC
aerohead (07-24-2014)
