Old 07-24-2014, 08:12 AM   #27 (permalink)
JasonG
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
The oil change indicator light can be changed with vcds.
They after come from the factory set for the gas interval.
For the TDI it should be 10k miles.
The issue in the states is that VW dealer service is lousy.
Make sure to change the oil using the correct spec and the timing belt before 120k miles and you'll be fine.
Ours has 65k and only a rear seat release cable that popped loose.
Well, there was a vacuum hose issue, but that was squirrel caused!
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
