Old 07-25-2014, 05:33 PM   #33 (permalink)
Arragonis
The PRC.
One other issue noted with the Octavia is that the cooling fans have run twice when the car has been parked and the engine has been shut off - this usually lasts between 2-4 minutes (estimated). A quick google suggests that this is due to a DPF regen being interrupted - e.g. by the end of the journey. I have VCDS and at some point I'll do a scan and check when it was last done.
Via the same route I've also found out that Hermann, my A6, has a DPF which makes him very "special" - I'll update that thread maybe.
