Originally Posted by backpacker3
Also is the spoiler going to affect anything? I was wondering because it seems like the back end is bad enough that it shouldn't make a difference. I also don't want to take it off because I think it would make a really good mount for a kammback idea I have.
ABA testing.
Is it better aerodynamically to have a grille block in front of a plastic mesh kind of grille or does it not make a difference either way?
Better to block than not to block. In front or behind probably to small to measure on most cars.
For wheel covers would having them on the inside of the wheels work as well as on the outside like you usually see?
Smoother is better.
http://ecomodder.com/forum/showthrea...tml#post418250
And finally (for now) is smoothing out the back end of a car (like in the area with the spare tire well on mine beneficial without a full belly pan?
http://ecomodder.com/forum/showthrea...tml#post436970
