Unfortunately Yolanda has been plagued with an AT, so even lifting the pedal at certain rpm ranges and engine loads I can't get her to shift until 2250rpm on level ground. I try to never top 3000rpm because I do have a VTEC engine that increases fuel sent after a certain rpm range is met. What throttle percentages do you typically run at during a normal acceleration from a light or stop sign?
-Scott (or Captain Red Beard if you prefer  )
