Originally Posted by figit090
Ok cool, so I guess it was fine to drive out of there? Still kinda sad though, and the tires weren't all inflated correctly. basically he didn't try very hard and I want a car that was maintained so I don't have to fix it. No timing belt by 155k was baaaad enough I should have known he wouldn't maintain the car.
OH and the description he gave of putting wd40 on the squeaky pulley was actually the external pully for the power steering like I thought, NOT the timing idler. I was wondering how he could take everything down the the idler and get oil on it without hitting the timing belt but then not replace the freaking belt!
So he didn't know squat about cars apparently and looked like a punk.
I thought these things only held three quarts?
I'd like to re-ask, do your cars (5spds) have backlash when you let off throttle? Or should you immediately feel road drag and no backlash between coasting/engine breaking and throttle?
No backlash, and mine holds 3.6qt. I put 3.6qt in and it only went to about 1/2 on the dip-stick, but I'm to lazy to add more.
