Old 07-28-2014, 05:11 PM   #26 (permalink)
brucey
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
OK, So I'm like a year late.
But, here is the idea and first proof of concept cover.
Was awful time consuming to make actually. I would say about 2 hours for the one cover. I haven't removed the backing on the rear lexan yet as I just want to see if it will work as a proof of concept before I do a complete version. Will be driving around for a few days to make sure it's not going to cause issues, then will probably re-do and touch up a couple things and make a set for all 4 wheels. I was thinking too: This should be possible to do by drilling directly into the wheel face and tapping it, but would be a permanent change. It would certainly be easier to line everything up then, also plan to change out the bolts with possibly a allen head instead of the 10mm bolt but thats minor stuff.
ID:	15451   Click image for larger version
ID:	15452   Click image for larger version
The Following 4 Users Say Thank You to brucey For This Useful Post:
aerohead (07-28-2014), jedi_sol (08-06-2014), t vago (07-30-2014), UltArc (07-28-2014)
