Thread: SUV Kammback
Old 07-28-2014, 09:14 PM   #6 (permalink)
UnicycleDan
EcoModder In Training
UnicycleDan's Avatar
BigBlue (UnicycleDan) - '03 GMC Envoy XL
90 day: 20.55 mpg (US)
Aerohead, I think I understand the concept of what you're saying. A question, though...I see that the Cd is decreasing as the tail of the wake is brought in closer toward the back of the car, but how do those angle drops in the second picture not produce a lot of turbulence, being so far away from the template? In your first picture, the template trajectories in the right column appear to be the same as their adjacent left column diagram. Do you have an explanation for why the steep angles in the left column produce a better Cd than their corresponding right column angles that follow the template more closely?
If my vehicle is 17ft long and I make a 2.5ft extension, then the kammback accounts for 13% of the total length, indicating I should use roughly a 14-degree decline according to the left column, which is not at all close to the template you advocate people superimposing over their car picture and following...I might be misunderstanding something.
"On the 8th day, God created kammbacks. And God saw that it was good."
-Genesis 1:32
